philco 60 dial slipping
When attempting to tune a Philco 60 the tuning shaft just turns without the dial turning. Does anybody have any ideas on fixing this  Thank you in advance. Norman
Is this the one with a bell-shaped cover going over balls pressing the shaft to the cap, bolted with two screws?
You need to clean under the bell, it works on the friction. Or simply tighten it first, see if it works.
Here's a post of my 60MB's tuner with the bell shaped cover that morzh is talking about removed. See what it looks like in there.
Hey Bob,
Was that the set you had up at ktown?
Yes indeed it was. Its now sitting on my desk at home, kinda glad it didn't sell to tell you the truth.
Next time don't bring it. Icon_lol
It was a nice radio indeed.
Keep it.
The $200 you wanted won't pay for the effort anyways.
Morzh  Thank you that is it. Norman
1 - 0v - correct 2 - 0v - correct 3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being o...morzh — 05:15 PM
