116B (121) won't fly
How critical is the wire gage connecting variable capacitor to coils.
I used real thin wire. Could that be the reason I can't this 116 going?
Danny
The cap to coils should be regular wire, not too thin. I am not sure this is the reason for whatever troubles you are having but the thinner the wire the more inductive it is and the inductance will distort the coil-to-cap connection and can, at least potentially, shift your frequencies.
There are currently 6531 online users. [Complete List]
» 1 Member(s) | 6530 Guest(s)
