Question I should know the answer to
If you have an isolation transformer and you plug in an extension cord to the output. You plug in your generator, signal tracer, and your AA5 set your working into the extension cord is it still isolated from the test equipment???
Come on you know the answer  Icon_lol
Hmm but then again you know the most complex
Questions and answers
Maybe you don't know the easy simple things   Icon_crazy
Other me
No it is not.
I in fact plug test equipment in the outlet and my radio in the transformer.
I didn't think so but I thought I'd ask. Got a RCA Strato Portable on the bench, battery/ac/dc.
