Threads: 367
City: Dover, OH
Here's the Atwater-Kent model 60 console I mentioned in a previous thread. Had it going fully for a short bit with no apparent issues, then the sound cut out. The good news is, after a recheck the speaker is just fine. My digital meter just doesn't have enough oomph to read all the windings in the field coil. It's plenty healthy. The bad news is, something on the chassis must have gave up the ghost. No funky smells or smoke, just kaput! Luckily all the expensive stuff seems fine yet. It will eventually live again.  I guess not all radios can be like the Radiola 66 I bought years back for $35. Still works great!
Threads: 12
City: Seattle, WA
I like the AK 60, not sure why. I have one my wife wants gone, but I'm reluctant to turn it out.
[Probably because it's in a cut-down cabinet. I keep hoping for a stretcher base to turn up, but it's been a year and a half and nothing reasonable yet. Maybe a nice Majestic 90 that someone wants rid of for $40? Nope, of course not. The only things I've seen are 4 hours away and the sellers want $350-450, usually in Canada.]
The grill design on yours is kind of unusual. I can't decide if I like it. But I do like the way that cabinet is toned. I hope if you refinish it, you manage to keep the coloring close to original!
Threads: 54
(06-18-2016, 03:33 AM)palegreenthumb Wrote: I like the AK 60, not sure why. I have one my wife wants gone, but I'm reluctant to turn it out.
Yes, I've seen those listed on Vancouver craigslist too, and no matter how much the sellers wish they never sell. $150-200 might be in the ballpark for a working model 60 in good shape. Of course there are also what I call the "Cocaine Induced" prices, like the idiot who thinks his pair of early CB sets is worth $800, after three years and no takers he should have figured things out by now.
With regard to A.K model 60s they seem to have been offered with several different cabinets, same with model 55s, but one thing you could do is put out an APB on the alternative forum and see if someone has a cabinet, either a good one or a junker that you could harvest the legs and stretchers off of. I think that there is also a swap meet in the Seattle area, there was one in Steveston just recently or soon too, maybe drop into one of those.
Threads: 112
City: Medford OR (OR what?)
I did just sell one of these, unrestored, but working (not guaranteed). As I was setting it up for sale it cut out. Also no drastic failure, just no sound. It turned out to be a rusty grid clip on one of the 224s. I have seen this before. Those AK clips were likely to corrode.
Threads: 367
City: Dover, OH
I had to replace a grid clip on this one before I tried it out. It was loose on one of the 24's, so I lightly squeezed it and it crumbled. I would say a capacitor or resistor gave up the ghost as the sound just faded out and that was that. Checked the tubes, even swapped tubes with no change.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
There are currently 6727 online users. [Complete List] » 1 Member(s) | 6726 Guest(s)
