model 60 decal
Hello all, what decal from Radiodaze is correct for the Philco 60 cathederal cabinet? thank you   Norman
This thread should help:
http://www.philcoradio.com/phorum/showth...?tid=13398
Thank you Nathan. Norman
There are currently 8611 online users. [Complete List]
» 2 Member(s) | 8609 Guest(s)
