Radio ID..
ALL, Here are 3 pictures of radios that have NO markings on them that I can find.. Anyone know the Model Numbers and years?
Thanks
Skip...
[Image: http://i292.photobucket.com/albums/mm38/...3gicsw.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...9uuu5w.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...32xt2r.jpg]
See if you can find them in here.  http://www.radioatticarchives.com/
Thanks Terry, However I cannot find pictures of them anywhere yet..
Will keep looking.. Any other places to look?
Skip...
I need a picture of the whole radio to be able to find it..
The top one has a name right on it between the knobs..
Kirk
The top one looks a lot like an RCA I recently thought hard about buying at a meet, Stromberg Carlson 430M?
Not too sure about the RCA console.
1st Radio between knobs say RCA Victor.. Missed that before..
Skip...
Ok, Found 2 out of the 3 radios.. The last picture of a RCA console not found yet..
Here is what I and other non this forum have found..
1. Rca Victor T-55 --RC-418 --1939
2. Stromberg \Carlson 430M 1939-1940
3. Last RCA Console ????
Skip...
last RCA maybe around 1948----1952,,,,
(07-11-2016, 09:40 PM)Kenneth F. Besso Jr. Wrote:  last RCA maybe around 1948----1952,,,,
 No, it's somewhat older then that period, no later then 1947 I would say. I would stay away from it since it's clearly a radio-phono combo unit and not a very high end one at that.
Found the last RCA Its a RCA Victor V-210.. 1941 I think..
Thanks to all for finding these..
Anyone know where I can get better schematic and parts list. I have the Riders from Nostaglic Air but quality is Bad.. Looking for a RCA V-210,. RCA T-55 and Stromberg Carlson 430M..
Thanks
Skip...
this might work for the v210 & t55
https://images.campyent.com/sites/defaul...pg13-1.png
https://images.campyent.com/sites/defaul...pg11-1.png
All, I picked up all three radios for 25.00 each.. The Stromberg cabinet is the best of all.
The parts alone are probably worth more than I paid..
Thanks all for your help..
Skip...
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6629 online users. [Complete List]
» 1 Member(s) | 6628 Guest(s)
