Philco Model 70 Wattage?
I would like to know what the wattage is for the Philco 70? I want to calculate the current for the radio.
Thank you,
Best Wishes,
Oscar
nv3g
According to the model label it nominally uses 80 watts:
From http://philcoradio.com/phorum/showthread.php?tid=14943 -
[Image: http://www.philcoradio.com/images/phorum/70label_id.jpg]
80 watts.
Edit: Nathan and I posted at the same time, I see...
Restoring Philco 96
There are currently 6841 online users. [Complete List]
» 5 Member(s) | 6836 Guest(s)
AvatarAvatarAvatarAvatar
