Philco model 90
You're doing great! Keep it up. Reminds me of a neglected water-soaked 90 I redid years ago.
 Making progress btwn. wind and high temps and humidity I got it this far. No toner yet. Should be getting the base trim for Steve Davis tomorrow.
[Image: http://i1336.photobucket.com/albums/o654...ilyoov.jpg]
[Image: http://i1336.photobucket.com/albums/o654...ftautq.jpg]
Looking fantasmic!
I got mine today and cant wait to dig in like you have!
Only 40 or so cabinets to get done before it, Icon_lolno
Me
  You are the king of getting them cabinets done. If you get time post a pic or two of the one you just got looked like a good one for restoration.
  Just a quick update on this one. Slowly getting there as the temp and humidity let me work on it.
[Image: http://i1336.photobucket.com/albums/o654...tjpaeq.jpg]
Nice.
Now the knobs Icon_smile
Thanks Mike. Yes I have to look around, I think I have a couple of the type for it. Been focusing on the chassis also got it recapped and playing on the bench. But I had to buy an universal P-P output tranny and adapt it to a model 20 speaker.
The one on my speaker was half open.
Had to do the same on a 20 and 90.
 Getting closer to being done with this one.
 Think I need more toner around the front and above the fluted coulombs also need to paint the inner grill trim black.
Comments on that appreciated.
 I had to make a backer board for the grill cloth and used the cardboard out of an three ring binder.
  Before[Image: http://i1336.photobucket.com/albums/o654...cp46b9.jpg]
 After.
Looks gorgeous, Mike! The 90 redux!
Beautiful!!!
Icon_clap Icon_clap Icon_clap
Great save! Icon_thumbup Icon_thumbup
Thanks guys. Still would like anyone's opinion on weather I should add more toner to the trim above the front arch and the horizontal pieces above the fluted coulombs.
I am going to criticize your work for the betterment of your skills...
  I am not sure of the toner but in the grooves of the columns it does not look even.
Are they just dents in the columns? I would definitely touch that up if it is not a strait line in each one..
I also see a paint fleck?
It is on the arch to the left in the picture...
Pick it out with a dental pick and color it...
MMMeee,,thinks it looks Fantastic,,,Cheers to that
Eico 232 VTVM Schematic
There are currently 7234 online users. [Complete List]
» 1 Member(s) | 7233 Guest(s)
