RCA Victor T-55 AM radio
#31
Ok, Realigned the radio. One of the IF cans was way off. Now radio receives signals all over the band..
Thanks Terry...
Now need someone to do cabinet..
Skip...
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
