Philco 70 Lowboy
I tried other 47's on my tester and they work fine on it. Even the untested one out my model 50 testes good. And each one varied enough to know my tester is good. I desoldered, then resoldered the pins on the defective 47 with the same results. Basically, after doing a quick reflow of the solder, I gave it three chances. Three strikes, it is now in file 13.
On a side note: I dug out my 90 lowboy. More on it later in another subject.
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4800 online users. [Complete List]
» 3 Member(s) | 4797 Guest(s)
