51-532 Knobs
Hello, I'm new here this is my first post, need both knobs for this radio 51-532 any ideas.
Thanks
Jim
Jim
Spring Lake MI
Welcome to the Phorum!
Icon_wave
You can try a couple of approaches for those knobs.
1) Check with the folks that are in the knob business.  I've used most of the people on the lists found on this page in the Resources section.
You may need to send a picture of the knobs you are looking for.  Some photos can be found on the Gallery pages.
2) Post in the Wanted Ads section and you may find someone has a set or some spare knobs.
(07-28-2016, 08:51 AM)klondike98 Wrote:  Welcome to the Phorum!
Icon_wave
Thanks
Found some.
Eico 232 VTVM Schematic
There are currently 7569 online users. [Complete List]
» 1 Member(s) | 7568 Guest(s)
