42-380 escutcheon related
Screws or tabs???
(08-15-2016, 06:39 PM)Warren Wrote:
(08-14-2016, 11:06 PM)spiderdrummer24 Wrote:
(08-12-2016, 02:39 PM)klondike98 Wrote:
(08-11-2016, 10:51 PM)spiderdrummer24 Wrote:   do you just hammer in the new ones after you drill the hole?
Welcome to the Phorum!
Icon_wave
no hammer.... screws screw in  Icon_biggrin
Ok but how do you unscrew them and screw them in? They have no groove
 Very carefully  Icon_crazy   actually you might be right about tapping them.in with a hammer. I have seen screws like that before. Does it have a head that looks like a round nail haad and are the "threads" different than it's screws? They kind of go up the screw instead of around aND around? If so then they need to be tapped in carefully.
Yeah they're drive screws.
Icon_wave
Sorry meant Sam's post with the pick.
terry
I had good luck with a fada 80 door that used what looks like screws like these. but smaller brass ones
used angled sharp pick. pulled straight up on sides little at a time
then used pliers and twist out
taped ever so gentle with plastic faced hammer luck maybe
Eico 232 VTVM Schematic
There are currently 7412 online users. [Complete List]
» 1 Member(s) | 7411 Guest(s)
