Tube tester covered with Tolex
Threads: 82
City: Annapolis, IL
State, Province, Country: USA
I have a tube tester I am restoring that has a wood cabinet covered with the Tolex. I have zero experience with this, so I am hoping for some tips before I grab the glue bottle and start smearing. I don't know if it would be best to try to simply re-glue the existing tolex or rip off and replace.
Tim
Threads: 55
City: Lexington, KY
I would just re-glue for simplicity and for originality. If when lifting up a section to apply glue it feels like the whole piece will easily peel off you might want to do that. Then you can glue the whole piece back on.
Threads: 310
City: Kings Park NY
There is absolutely no reason to re-cover. Spray adhesive on both pieces, wait a few seconds and bond.
I have saved many coverings this way..
The one below was peeled half way off all around...
Me
AC: 4 DC: 1
Threads: 54
Other then the glue letting go near the edges the oil cloth/leatherette looks like it's in fairly good shape so I would try gluing it back down rather then recovering the case, recovering the case would be close to performing a re-upholstery job. It may be a good idea to clean under the areas that are lifting before gluing them back down, glue doesn't stick well to dirt and dust.
Threads: 82
City: Annapolis, IL
It feels like the rest of it is pretty tight on there. I have some Tolex glue and I also have some spray glue. I think I will try the tolex glue 1st and see what kind of result I get. Looks good Kirk! Thanks for sharing! Got some rusty hinges and clips to deal with also.
Tim
Threads: 112
City: Medford OR (OR what?)
I got one recently that had termites in the wood as well as a bad cover.
I guess that I could make a lid too.
I would just re-glue yours.
(This post was last modified: 06-03-2016, 06:44 PM by Phlogiston.)
Threads: 82
City: Annapolis, IL
With the Electronic part of this restoration finished, I have moved on to the cabinet. The hardware is rusty. Some of it cleaned up nicely with the wire brush on my Dremel tool. Some didn't. The tolex appears to be fairly poor quality, and the install not so good either. I am debating on recovering or re gluing. Several tears and cracks, corners torn off, etc. AES has some hardware, like the feet and a handle, but I haven't found any hinges or latches. Does anyone know where I can find these items? Or even what terms to use for internet searches? This isn't for show, but I do want it to look decent.
Tim
Threads: 82
City: Annapolis, IL
I have started the repair. Note: repair. I decided to try regluing the tolex first. I used the tolex glue from AES. I will post the results later.
Tim
Threads: 310
City: Kings Park NY
Cant wait to see her!
AC: 4 DC: 1
Threads: 82
City: Annapolis, IL
Tim
Threads: 337
City: lawrenceville nj
Threads: 310
City: Kings Park NY
That is Fantastic!
AC: 4 DC: 1
Threads: 11
City: Christchurch, New Zealand
![Icon_eek Icon_eek](https://philcoradio.com/phorum/images/smilies/icon_eek.gif) stunning transformation! Awesome job...
... do mine next?
There are no personal problems that can't be overcome with the liberal application of high explosives
Threads: 82
City: Annapolis, IL
Thanks guys for the compliments! Steve, I sure don't envy you, but I bet you can make something out of that project. Sure makes things easier getting how to's from folks that have 'been there, done that! Thanks again!
Tim
Threads: 73
City: Riverside, CA
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
There are currently 9829 online users. [Complete List] » 1 Member(s) | 9828 Guest(s)
