Silvertone refinish
Wanted to show off this very good looking 1939 silvertone table set I had refinished and recapped. Picked off Craig's list $50 , not bad at all.
   Very nice Fred  As always you do a very good job of making the radios look like they have not been refinished.
  I do like the style of this one, it has a very warm look to it .
 Thanks for showing it .. Dan in Calgary
   Living in Calgary Alberta
Fred, nice radio! Clean styling on that one. Good to see you back in production!
Looks good!
Very nice Fred!
Crist
Nice curves on that cabinet, those Silvertones with eye tubes are getting big$ these days. She is a looker! Icon_clap
Paul B.
I Love the look of that radio very much nice job and the price was right!  Icon_thumbup
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
