Philco 49-607 Code 121 Schematic
Hi, does anyone have a Schematic for Philco 49-607 Code 121? I have checked at Nostalgia Air and they don't have one. Thank you, bigdog
I downloaded a Riders off his site a couple of weeks ago. 49-607, but not sure about the code 121. Nice radio.
or. if you contact Chuck Schwark he will probably have it. His copies are very good.
There are currently 6279 online users. [Complete List]
» 2 Member(s) | 6277 Guest(s)
