42-380 dial cord
Well it's finally come time to replace the dial cord on my 42-380. However the only replacement cords i can find are .030 diameter and .040 diameter. Which one is the one?
I just measured my original 42-380 dial cord. It is .030" diameter.
Dial calipers can be handy.
Do you have an idea as to how to get these clips off the end of the cord? Around the loops? I've tried pliers and everything else and no luck yet
Often people don't try to reuse those clips (if they are what I think you are talking about) they make loops or knots at each end. Here's one thread about it:
http://philcoradio.com/phorum/showthread...+cord+knot
Restoring Philco 96
There are currently 6437 online users. [Complete List]
» 5 Member(s) | 6432 Guest(s)
AvatarAvatarAvatarAvatar
