PHILCO MODEL 52 CATHEDRAL
I HAVE A MODEL 52 CATHEDRAL THAT I AMP RESTORING. MY QUESTION IS ABOUT THE METAL BOX OF CAPACITORS. THE SCHEMATIC DOES NOT SHOW WHAT VALUE IS CONNECTED TO WHAT COLOR WIRE. THERE ARE 5 CAPS IN THIS CAN. ANYONE RESTORED ONE OF THESE?
David Regira
Dave,
The leads may be marked the same as in the model 37:
http://www.nostalgiaair.org/PagesByModel...013194.pdf
Carl
Northern Panhandle, WV
CARL, Thanks. You are probably right. It looks like the same can as the model 37
David Regira
91H Code 126 Restore
