680 decals
Just got the decals for my 680.  There are 2 types,  one with the high fidelity in a script,  the other in plain type i looked at the photos on this site as well as the radiomuseum site and the decal cant be made out. Does anybody know which one is correct for the 680X late production? Thanks in advance  Norman
Plain type, not script. The script version ("High Fidelity" in script) was used on models 38-116XX and 38-690XX only.
Thank you, Mr Ramirez
