Philco 38-5X
(10-13-2016, 10:10 PM)Radioroslyn Wrote:  >What is the black shiny junk at end of the tuning cap stack?
Looks to be what's left of the rubber mount for the cap.
You've tons of room in that chassis. Also looks like it's
a Canadian built model w/a 25cy power transformer.
Any idea where to get those tuning cap mounts or even a picture of a new one? I know the corner mounts are available.
TerryMSU
TerryMSU
Same place just rubber washers.
Renovated Radios sells the proper mounts. They are the same as used on the 38-4, and the very rare 38-250EZ. At work so no time to look up the part number for you, sorry. Go to Ed's website and you can find them.
http://www.renovatedradios.com/
Restoring Philco 96
There are currently 7594 online users. [Complete List]
» 3 Member(s) | 7591 Guest(s)
