10 radio cabinet restoration chronicles
#46
Mine is an honest opinion; then again, since I know squat about cabinetry, it's only worth so much. Icon_lol
#47
Thanks all...
I always question myself which is good and bad....
This is a keeper for me so I want it to be better than the stuff I do for you guys Icon_lol Icon_lol
Me
 It looks all right to me Kirk, I have a few Philco's from that era, like a 42-327, and the grill bars, wood dial escutcheon, and base look black to me, same with a Canadian made Philco battery radio I have.
Thanks all,
  I finally finished my pair of Utah speakers!
I also finished the Croyden I smashed the grill on...
I am happy with the results..
My arms are tired from rubbing, Icon_lol
The Croyden will go to Mike.. I did everything I could but someone changed it underneath so it does not work Icon_sad
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
