AK 856 chassis mounting screws/bolts?
Can anyone here tell me what type of screws/bolts were used to secure the chassis on an Atwater Kent 856 tombstone? Thanks!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
