Transformer 32-8341 info needed
Chuck can't help me, so does anyone know the parameters?
It is large, with a single CT secondary that reads over 1kV with 120 on the primary.
Dennis
Pacing the cage...
Do you happen to know what it was used in or for?? Pic ??
No.
d
Pacing the cage...
Restoring Philco 96
There are currently 7460 online users. [Complete List]
» 3 Member(s) | 7457 Guest(s)
