Threads: 17
City: Newbern
State, Province, Country: Tennessee
Hi all,
I just received a 40-84 and the case is very dirty. My question is what is the best way to clean it and also is the case lacquer coated?
Richard
Threads: 9
City: Vieques, PR USA
State, Province, Country: PR
I don't know that particular model number but i think its safe to say that on a 1940 model that its lacquer. Soapy wet rag works fine for cleaning. Rinse off with a damp rag. Don't 'wet' the cabinet and I'm sure it will come out fine.
Threads: 17
City: Newbern
Thanks for the reply. It is the portable a/c, d/c model. It looks like a tweed suit case. I just want to clean it with out damaging the material. Also I t looks like the tweed is protected by lacquer or something.
Richard
Threads: 9
rjm Wrote:It looks like a tweed suit case. I just want to clean it with out damaging the material.
Okay, same advice applies.
Good luck with the project.
-Bill
Threads: 17
City: Newbern
Well I have tried soap and water, Polish and even brasso and no luck. I am thinking whatever they used to coat it is what's changing the color to look like its dirty.
Any other suggestions?
Has anyone come across this? Any help would be appreciated.
Richard
Threads: 18
rjm,
Please post a pic of it. We'll be able to help more with a clear visual.
Joe
"Ignorance is bliss...'til you have to fix a radio..."
Threads: 17
City: Newbern
Thanks for the reply,
Here are three pics. The one from the side shows how dirty it is. The pics make it cleaner than it is.
Richard
Threads: 18
I had a similar case a few years ago, it wasn't a Philco though. On that one it was a woven material and the protective coating was dirty and stained. Very carefully I tried various solvents in an inconspicious spot and found that I could blot off the coating to the fabric with alcohol. I did that, and got to a reasonable stage, and harvested a strip of the material from inside the case to mend a couple of worn and torn spots. Then I sprayed the thing with orange shellac, and it looked 100% better, although not 100% perfect.
Threads: 17
City: Newbern
I will try the alcohol and see what happens. I got lucky that the only damage is in the corner and it is relatively small.
You used orange shellac not lacquer? I thought they left behind shellac and was using laquer for everything by this time.
Richard
Threads: 18
Hi Richard,
That's a pretty neat looking case, I haven't seen one before -- but am familiar with that type material. I agree with codefox on the alcohol. But, if that doesn't work, I would personally use mineral spirits and a medium bristled brush. Of course, try on an inconspicuous spot first, but this is what I use in most cases on similary projects. I find the brush will more thoroughly and safely clean the textured surface than anything that rubs across the peaks of that textured surface. Anyway, just my .02 worth. Hope that helps.
Joe
Threads: 17
City: Newbern
Thanks for the response. I tried the alcohol and it did remove a little. I will try your advise on the mineral spirits. The brush is it better natural or synthetic bristles?
Richard
Threads: 18
Does not matter, as long as the solvent does not dissolve the brush. The most dreadful last measures are all outdoors, and include gasoline, acetone (nail polish remover) and finally bleach. All in tiny measures, and blotted quickly. In the end the gray color scale will count more than the actual hue. An antique appearance is what we want here, that's why I used an orange shellac on the one I did. And you can fool around all you want with oil stains and let it dry a week before you coat it, and you'll be OK. Have fun!
Gloritone 27 Radio
I have a model 27 that someone painted the cabinet brown. I've been trying to sell it for awhile but the cabinet paint m...Jim Dutridge — 02:30 PM |
Restoring Philco 96
Joseph
Yeah. The situaction is complicated by me living with my family in NJ while mom is in FL.
Were it not for my ...morzh — 10:55 AM |
Restoring Philco 96
Best of wishes for your mother. I hope she recovers well. My mother struggles with sciatic pain as well, so I am familia...jrblasde — 10:41 AM |
Restoring Philco 96
Well, because I am away, I cannot check it. Hope mom becomes better enough for me to get back.
I think I will be here f...morzh — 10:27 AM |
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM |
Gloritone 27 Radio
Hello john,
That, is the first time I have have seen or heard of that brand and model.
Welcome to the party !!
Sincer...radiorich — 08:08 AM |
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM |
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27:
A little bit of extra t...Eliot Ness — 05:48 AM |
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM |
42-345 Resistors
Great comments.
I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM |
