Threads: 9
City: Springville NY
State, Province, Country: NY
Threads: 69
City: Kansas city, MO.
Hi Mike. Do you have a frequency counter? If so you can hook the signal generator to it and check for accuracy of the generator. You probably should replace the electrolytic caps in it.
Other members on here can give you more detailed advice on what you should do.
Here is a video on one very similar to yours that could help you with how they work.
https://www.youtube.com/watch?v=eE7J4Kpbe6w
City: Lompoc CA
Just started my signal gen which is the same as yours today. I found the video useful. My ver Generator looks more like yours. C108a-b is still a little confusing. My schematic is different that the older ver on the youtube
City: Lompoc CA
Still a little confused about how to attach the filter cap C108 a-c I watch the you tube by Dr Carlson it is an earlier mod. The 25uf pos is grounded Im confused as to the neg. Have you replaced these yet? I need to get some inline safety Caps as well. I did replace c107 and c109 only the .02 was off i see yours was replaced. But i could not see the .01 across the AVG JACKS . In circuit all my c108 are reading 9uf so thats why Im replacing them.
(This post was last modified: 11-21-2016, 01:47 AM by Bradley Rush.)
Threads: 9
I haven't started on mine yet. it is next in project order after Thanksgiving as I really needed it during my last radio project. I watched that video as well. Very informative. I don't have the resources he has but I understand the process he was using. Mine is S/N D58432. I found a schematic for mine dated 1957 which I believe is when mine was made by some of the markings inside. I can email you a copy if you haven't located one. Its actually the operating instructions as well. It looks to me that the positive ends of 108b & c are connected in relation to the negative side of 108a. Others with far more experience than I would be willing to help I'm sure. This is a great forum with a plethora of info and great people.
Threads: 69
Here is a downloadable schematic for who ever needs it. There is two. The first one someone has made a lot of notes and looks like changes. I wouldn't recommend that one.
http://bama.edebris.com/manuals/paco/e200c/
Threads: 268
If your not in a hurry, I've used this for a counter:
http://www.ebay.com/itm/RF-Signal-Freque...SwpDdVUNSY
Takes about 2-3wks to get it but have ordered a couple and hasn't been any problems.
It can also can be used as a digital readout on a single conversion superhet as you can program it to + or - the IF frequency from the LO frequency. Instruction are in Chinese but there is an English YT vid on how to set in up and wire it.
(This post was last modified: 11-22-2016, 12:39 AM by Radioroslyn.)
Threads: 562
Have you had sleep disruptions after looking at it?
Blue light causes that.
Threads: 268
They come in a couple of different colors that one was the first that came up on a search. You can also set the brightness via a button on the back. Mine are yellow and are 1- 200mc or so. Big bicycle not a rent a car.
(This post was last modified: 11-22-2016, 02:26 PM by Radioroslyn.)
Threads: 562
I mean...yes this is cheap. Can't beat that.
I got my B&K counter, which is pretty accurate, for $25 or so plus shipping (wasn't that much).
It still make sense to look for old equipment bargains on eBay or locally.
Threads: 268
I picked up an old BK years ago. I think it's a 1801? Used it as a counter to check the frequency of my old AM ham station. Worked ok but isn't sensitive at all. 1970's technology. I like the programmablty of this new one. By the time you buy a box and rig up a p/s you may be up to $20 or so...
Threads: 562
Speaking of the sensitivity actually, when I use it with my Leader SigGen, it shows correct frequency at the minimum output.
The 5V input does not work, but then I do not even need that. Else I'd fix it.
Threads: 14
City: Irvington, NY
Hey Terry, those Chinese counters look real nice to add digital readout to some of my old boatanchor receivers.
How do you program in the IF offset? Do you need a computer interface or is it done with jumpers or with pushbuttons on the PCB?
Threads: 268
(11-23-2016, 10:22 PM)Mondial Wrote: Hey Terry, those Chinese counters look real nice to add digital readout to some of my old boatanchor receivers.
It's pretty simple two small pushbuttons on the back of the pcb. No switches or interfacing to mess with. I know a HRO that is going to get one!
https://www.youtube.com/watch?v=1_neC5Z_wEg
It just takes a few minutes to figure it out the buttons/function.
Threads: 14
City: Irvington, NY
Thanks, the video really explains everything. I just ordered one.
I don't know how they can build and ship this counter to the US for $9 and change?
Terry, do you ever operate 40 meter sideband? I just finished restoring a Kenwood TS-420 Hybrid and finally got back on the air recently with a random longwire antenna. Maybe we can work you one day?
Mike WA2YGA
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Var resistor id
Var resistor id
Var resistor id
Its a Sylvania 400 oscilloscope. here is a clip of r-100. Would be nice to know the current required. Not listed in part...Martinj — 02:10 PM |
Thanks Richard. I hope you enjoy it.
Here I have created an English section on the history of radio with videos in Engl...RadioSvit — 10:23 AM |
Hello RadioSvit,
first all happy new year !
I will watch your new videos this week.
Sincerely Richardradiorich — 09:19 AM |
There are currently 5644 online users. [Complete List] » 1 Member(s) | 5643 Guest(s)
