Ron's 2016 Cabinet Work Part III: 38-624T
#31
Nice job Ron, always like that style cabinet.
#32
A+ Ron
Me
Ron. I do like the way it turned out.
 Very nice job, you should be proud of that one.
 Dan in Calgary
   Living in Calgary Alberta
#34
Thank you, Dan! That is very kind of you, considering the beautiful sets you have redone and which you have shown here on the Phorum from time to time. I really appreciate the compliments!
And thank you too, Fred, Kirk, Greg, Sam, and everyone else who commented. Your kind words are very much appreciated. Icon_biggrin
Is Wally World Walmart? I know silly ? but I am curious.
Nice work, coming up niccceee.
She's a good-lookin'.
#37
Yes, Wally World = Walmart = The Nut House. Icon_lol
Thanks Paul (and Mike!).
This is an old thread that has received attention more recently, so go here (and scroll down a bit) to see the complete radio, 38-624T with a 37-640 chassis:
http://www.philcoradio.com/phorum/showth...760&page=5
Philco 91 Tuning Condenser
There are currently 10175 online users. [Complete List]
» 2 Member(s) | 10173 Guest(s)
