1933 zenith console cabinet restore.
  I think I out did myself on this one, I added some of my own touches that didn't come from factory, this is what I call eye candy for the antique radio lover. Before and after pictures tells it all.
few more
 Just beautiful Fred. Icon_thumbup
How does it sound with the two speakers?
Sounds very good, 12 tube set. Electrical has been done also.
Beautiful, Fred!
I can't really say I like the grill cloth, but I do like the way you aligned it with the features of the wooden grill. Very nicely done. Is the cloth a legit loose-weave grill cloth, or is it some other type of cloth?
The grill cloth is not loose weave, your the second person that didn't care for the cloth design. That prompts me to consider changing the cloth out to something else. I will check RD and Richmond Designs for something that will be more suitable, some of Richmond's cloth is very nice and a few others I don't care for. I do like to here from folks for there opinions. All in all I think the zenith is a keeper for a while until it is sold and rotated out of my collection. Thanks for your honest opinion.
Great job.
Ditto on the cloth - too speckled, not Zenith style.
If you can't get the original (looking) cloth, I would say that looks fine.
I agree with ,others on the grill cloth. Although I try to put something on that is as close as possible to the original,
or at least period style.. I would change the grill cloth, if it were mine.
Dan in Calgary
   Living in Calgary Alberta
FRED,,wye you live soo,,Far away,,,,,Beautiful Workmanship
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
