#61
lol Icon_lol
I like how you phrased that
Now you know that's not the right answer!!!!!
sam
I think 0.6 Ohm is what it should be
#63
Or "less 1 ohm" ?
#64
Or is it "less 0.1 ohm"
#65
I think Sam is referring to the missing punctuantion after "powered off" Icon_smile
Truthfully, took me a while to understand it too Icon_lol
"EXECUTE NOT PARDON". Which one is it? Icon_lol
#66
I think there is a disconnect. I was just saying the the resistance from pin 7 was measured to be 0.6 Ohms with the radio powered off. Then I was following the line from the pin on the schematic and was thinking that the resistance is written as "less 1 ohm" or possibly it says "less 0.1 Ohm" there.
But I did have a laugh at "Now you know that's not right"
#67
Still not the right answer!
I was looking for something open.
Ha! Ok what's the right answer? That tube should be 70V but its low. We tried disconnecting one end of 17 a week ago but that didn't raise the voltage.
#69
Ok I'll look for something open
#70
Well there isn't anything that isn't supposed to be
#71
(12-08-2016, 10:23 PM)ccbaker13 Wrote:  Well there isn't anything that isn't supposed to be
Well as Peavey the druggist would "I wouldn't say that"! The voltages aren't.
Does #27 measure 4.7K? and what are the voltages on both sides of it.
I get 4.7K and 10 volts across it
#73
Oh sorry, 190V and 200V
#74
Reminds me of chess playing Icon_lol
#75
Yeah this radio is Bobby Fischer
Users browsing this thread: 29 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8957 online users. [Complete List]
» 3 Member(s) | 8954 Guest(s)
