marconi 157
got a bunch of cousins up there ,,Holyrood,,,Bell Island---I love it in thee summer,,,ONLY
(12-08-2016, 08:28 PM)BrendaAnnD Wrote:  I got to seriously looking under the chassis of this thing... someone who knows NOTHING about electronics has worked on it. There are resistors that have been put in parallel that should be in series (voltage divider), missing resistors, a large cap to ground from the grid of the output tube... lots of fun carp. This is going to be a lot of work.
when you say large cap do you mean electrolytic cap
(12-09-2016, 06:18 PM)Kenneth F. Besso Jr. Wrote:  got a bunch of cousins up there ,,Holyrood,,,Bell Island---I love it in thee summer,,,ONLY
do any of your family out there do radio repair
(12-08-2016, 08:48 PM)morzh Wrote:  The caps...CapXon....never heard of these.
Seriously. You need to get someone with experience to look at it.
Mike;
  Consider yourself fortunate that you haven't. Capxon is one of those Chicom mystery brands of caps that are on the hall of shame list over at badcaps.net. They are so bad, and have caused so many premature equipment failures, that people call them Craps-on as well as other more expletive names. In this case it is on the cathode of the 6F6G tube so even if it was dead shorted it wouldn't kill anything, but it surprises me that Just Radios would pedal such an infamous brand of capacitor.
thanks for the info
NO,,sorry,,they don't repair radio's
got the motor boating fixed
What was it?
it was a wire shorting out the primary and secondary of one of the if transformers
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7104 online users. [Complete List]
» 1 Member(s) | 7103 Guest(s)
