Philco 70 field coil
 Hard sometimes to believe how much wire is on the small bobbin. Project for tomorrow. Icon_e_surprised
[Image: http://i1336.photobucket.com/albums/o654...iw9pab.jpg]
Weigh the wire and bobbin together, then weigh the wire alone. Spool the new wire on the bobbin until it reaches the weight of the combined items. Usually you're with 1 or 2% of the needed resistance at this point provided you're using the same guage wire.
Thanks Jim for the advice. I will give that a try.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7974 online users. [Complete List]
» 3 Member(s) | 7971 Guest(s)
