Sparton 69 Equasonne
http://www.russoldradios.com/blog
You've been a busy boy Russ!
(12-17-2016, 04:17 PM)klondike98 Wrote:  You've been a busy boy Russ!
Icon_thumbup  Icon_thumbup  Icon_thumbup
I am not one to leave a pile of anything lying around for long.
Actually I still have 2 large speakers to deal with. One is a RCA 104 the other is a Stewart Warner built for a 800 series receiver both in good cabinets.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
