42-380 grommets
One day, I'll learn this by myself and I won't have to bug yall all the time. Lol. On the variable capacitor, the 4 grommets that keep it mounted have fallen to pieces. What size are they? Radio daze has some but I do not know which is which.
I'm not sure what size you have on your set but the fellow with the most selection of grommets like that is Ed at http://www.renovatedradios.com/parts.html
I've looked everywhere and still can't find anything
I usually go to Lowes, go to Specialty items drawers, find grommets and measure them against the old ones plus the metal ferrule that goes inside (if present).
So far worked for me just fine.
Well unfortunately these grommets are falling apart and crumbling in my hands so it's really hard to get a good reference
Good Morning, alone with what mike said pick up a set of Orings at your local HF and super glue and have fun. David
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8534 online users. [Complete List]
» 3 Member(s) | 8531 Guest(s)
