Philco Q-1568-WA Question
Threads: 1
City: Philadelphia PA
Hi Everyone,
I have a philco q-1568-wa that I bought from someone off of craigslist. It is in good shape, the radio and speakers work great and mechanically the record player works great, but occasionally (more frequently than not) the sound cuts out while records are playing. I thought it might be a bad needle, so I replaced it, it played a whole stack no problem.
But then the problem returned. Usually a quick tap to the side of the player will bring it back but something is definitely wrong. Any thoughts on what it could be? And how I can go about fixing it?
I would appreciate any help you may be able to offer!
Joe
Philadelphia
Threads: 566
Joe
Welcome.
Instead of quick tap you might want to gently wiggle wires, especially those coming from the record crystal adapter (or what have you) to the radio. If there are connectors, inspect those.
It is a bad connection, likely in the adapter wiring or connectors.
Threads: 271
City: Wilsonville
State, Province, Country: OR
Welcome to the Phorum!
Threads: 1
(12-21-2016, 02:06 PM)morzh Wrote: Joe
Welcome.
Thanks Morzh! I was nervous about that, the wires are extremely thin and I am sure there may be a bad solder connection. It never occurred to me to check the crystal/cartridge. I guess I will just keep traveling along the signal chain and repair what I can.
Joe
Threads: 1
(12-21-2016, 08:12 PM)klondike98 Wrote: Welcome to the Phorum!
Thanks Bob!
Threads: 268
Hi Neighbor and welcome,
Since your set is a portable, as Mike suggested some sort of bad connection. This could be loose wire, poor solder joint, or a crack in a trace on the circuit board. When does it act up? Does it behave badly in the radio mode too?? I suspect that your set is close to 50yrs old (mid '60's)
(This post was last modified: 12-22-2016, 01:17 PM by Radioroslyn.)
Threads: 1
(12-22-2016, 01:17 PM)Radioroslyn Wrote: Hi Neighbor and welcome,
Hi GL, it acts completely fine while the radio is on. I listened to an entire football game one Sunday with no problems. The speakers sounded great. It only acts up with the record player.
I can't find much information on the unit itself. But I too suspect it is from sometime in the late 60's since it is AM/FM.
Joe
Threads: 268
(12-22-2016, 01:58 PM)Joebusiness04 Wrote: (12-22-2016, 01:17 PM)Radioroslyn Wrote: Hi Neighbor and welcome,
Joe
Hi Joe,
GL is short for good luck. If you see GLOM it's kinda a ham thing good luck old man.
Well that's a good thing that it's only the phono that acts up. Didn't look for a schematic for as I'm more of a tube guy rather than a transistor.
Took a quick look and found this
https://www.samswebsite.com/en/photofact...el/Q1568WA
You could try posting a want ad here and on the barking dog forum, someone may be willing to scan it for you for free. You can order it on line @ $22. This will have lot of pics and replacement part numbers ect... To be specific what you are looking for is Sam's Photofact 893-6. Sometimes they can turnup on Epay too for $5 or so. Sorry I have deep pocket but short arms!!!
(This post was last modified: 12-22-2016, 02:22 PM by Radioroslyn.)
Threads: 1
Terry, sorry, evidently my brain went out for lunch and left me at my desk.
Thanks for the link, it is super helpful, I greatly appreciate it!
Joe
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
I forgot how the pointer is formed: could you show the way it is formed and how you tried to change it?morzh — 07:01 PM |
Was that pole piece left handed ?
Since the metal "spider" is toast, wonder if you can either get the "4...MrFixr55 — 06:54 PM |
There are currently 9156 online users. [Complete List] » 3 Member(s) | 9153 Guest(s)
