Philco 54-6182-1 part number
Threads: 563
It's Kirk's. Dunno what the radio model is (small white clock radio).
Need the sch or at least the IF value.
When clock disconnected seems to receive but very whistly and howly.
Also the 12BE6 pentagrid is very weak.
http://www.philcoradio.com/phorum/showth...p?tid=9215
Surfaced up here before.
Threads: 310
City: Kings Park NY
It is a Philco 1955 white plastic 720. This color is the C-720, there is also a D-720...
I cannot find ANY info online. The only reason I know the model is from an original 1955 clock radio AD.
It is pictured int he 1955 section of the Philco gallery.
AC: 4 DC: 1
Threads: 563
Kirk gave me two 12BE6 that are strong.
The radio clearly needs alignment.
Threads: 563
Well, here's some. Although there are some mistakes there.
http://www.introni.it/pdf/Radio_diagrams_1955.pdf
I found some in DjVU format but cannot get back on that website - forgot what it was. The same manual though.
The 720 is said to have the same sch with
C580 or C716. While the PCB does look the same format-wise, it only has 4 tubes and ours has 5 tubes.
However C-722 sch does look similar, 5 tubes with the 12BE6 pentagrid and clock connection.
Could be it!
Threads: 310
City: Kings Park NY
Woohoo!
Now Fix it,
AC: 4 DC: 1
Threads: 563
(12-27-2016, 12:06 PM) OldRestorer Wrote: Woohoo!
Now Fix it,
Everything I find on the web on 720 shows the wrong sch although with the same size/format PCB. It is a 5-tube radio and 720 is listed with the rest of 4-tubers.
Actually even in Sam's Photofact here
http://www.todocoleccion.net/radios-anti...~x31883793
OK, well, hopefully the sch is right of what I have found for C-722.
Not tonite though.
Threads: 563
OK, you dummy.....
It is a Philco D730.
http://www.philcoradio.com/gallery/1956.htm#s
And this is the sch.
http://www.techpreservation.com/schematics/Philco.htm
I converted it to PDF.
PS. And, yes, I was right before: the C-722 schematic is practically the same (minor differences) and the tube line-up is the same.
Threads: 310
City: Kings Park NY
Hmmmm,
I only went by online and the pictures I found...
Good detective work...
AC: 4 DC: 1
Threads: 563
That will cost you a console cabinet!
A big one.
Threads: 310
City: Kings Park NY
You are too funny
AC: 4 DC: 1
Threads: 563
Wait....two cabinets. Both chassis involved detective work.
Threads: 29
City: Wellborn Florida
Will try and upload sch file size is 956kb to big! David
Threads: 29
Try try again. Hope this helps. David
Threads: 563
David
Thanks but it does not help. As you could see from this discussion the radio is either not 620 or the sch is not from 620: the radio I have is a 5-tuber and is likely a .730.
Yours is 4-tube radio.
Might you by chance have the 730 sch with good resolution? (I can live with what I got but resolution helps).
Threads: 563
Anyway
Attempted alignment tonight. IF was a bit off. Cannot peak oscillator at 1620 kc.
Plus during the tuning the cap really makes grinding noises. Maybe I should clean the dang cap. Plus tubes' pins and sockets. It's a simple radio but it behaves strangely.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM
There are currently 2919 online users. [Complete List ]» 1 Member(s) | 2918 Guest(s)
