Kirk's Emerson 804A
Suffices it to say that I started it about 4:30pm and it worked two hrs later. In fact it started working while Kirk was sending me the schematic.
All I have done was
1)recap - 4 tubulars (someone replaced the electrolytic caps)
2) changed bad ballast-rectifier tube
3) replaced a wrong tube (12BA6 was instead of 12BE6). Plus this and another 12BA6 were swapped.
4) soldered the magnetic antenna. It was missing and Kirk told me it was in the tupperware container.
I worked with no sch as I realized the radio is very simikar to the Philco clock radio I just finished. Plus it was not recapped so no damage by others Icon_smile
That was quick!
 Sometimes its nice to have an easy restoration that goes well. Icon_smile
Yeah,
 A n easy restore is great.. How about an easy cabinet or two!  Icon_think
(12-30-2016, 08:47 PM)OldRestorer Wrote:  Yeah,
  Icon_lol  I haven't been that lucky yet.
Easy. Easy? If it were easy you would not give them to me Icon_lol
I make it look easy!
(12-30-2016, 10:31 PM)morzh Wrote:  ........I make it look easy!
Our Russian chassis whisperer Icon_e_wink
Yep. They talk to me. Literally. Icon_lol
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3526 online users. [Complete List]
» 1 Member(s) | 3525 Guest(s)
