Threads: 55
City: Lexington, KY
That cabinet has very good photo finish. Those black dial Zeniths are pretty desirable and the three knobs are worth about $60 (if they are the wooden Z knobs). The chassis is a bit rough, but if I had to make an offer it'd be between $75 - $125.
To clean the dial start I'd start with plain water and a soft cotton or microfiber cloth and then a mild dish washing mix if needed, from there you can try other stuff if needed. As with any dial, start in an inconspicuous spot to make sure it will be safe.
Good luck, those are pretty neat radios. My first radio was a similar 5-S-127 that I was given as a teenager and still have it in my collection.
(This post was last modified: 12-19-2016, 11:43 AM by Eliot Ness.)
Threads: 268
Sometimes it will evaporate and go away on it own after a few days.
Threads: 140
City: Lansdale
State, Province, Country: PA
Ok, Parts came in.. The replacement belt for the tuning was installed and working perfect.. Now on the the Capacitor Replacement..
Need to still clean the dial..
[Image: http://i292.photobucket.com/albums/mm38/...0nphbv.jpg]
The spots didn't evaporate..
Skip...
Threads: 268
(12-29-2016, 08:47 PM)vecher Wrote: Ok, Parts came in.. The replacement belt for the tuning was installed and working perfect.. Now on the the Capacitor Replacement..
Skip...
Back to post 16.
Threads: 310
City: Kings Park NY
It looks like when you hit it with splatter from a WD-40 can...
It will take more than water to get off... USe some Gojo very lightly on a tissue. I have never seen it take off dial color or numbers.. Except for philco's,
AC: 4 DC: 1
Threads: 140
City: Lansdale
Ok, All Just finished up the Cap and Resistor replacement. Brought up slowly and at 115 Volts Draw was .5 Amps.. Its alive!!! Received stations on all bands with only a 2 foot antenna.
Now on to cosmetics since I now know it will work great..
Then on to alignment..
Stay Tuned Same Bat time same Bat channel..
Skip...
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 310
City: Kings Park NY
Wonderful!
AC: 4 DC: 1
Threads: 140
City: Lansdale
Ok, Noticed when I started alignment that at low end of the bands when moving the tuning I would hear all kinds of noises. scratching sounds.. When I get to about 600 on AM band noise and scratching goes away. I decided to remove the Tuning Capacitor/. I measured the Cap and one side was OK other was shorted until I got a little way up then all was fine..
See Cap...
[Image: http://i292.photobucket.com/albums/mm38/...9buk7w.jpg]
Question is ... How do you clean this? I thought I would try cleaning in case that's all it is .. Something is shorting.. I looked under a Magnifier and saw nothing that looked like it was touching..
Thanks
Skip...
Threads: 271
City: Wilsonville
I have dunked the entire tuning cap in Metal Rescue for a few hours, a derusting formulation, that cleaned of the rust on my model 50. I have read some have put them in the dishwasher and others in a sonic bath.
Threads: 103
City: Calgary, AB, CA
I have just sprayed it with a good degreaser and used a toothbrush.
Then sprayed down with water to rinse off the degreaser. I used a hair dryer to dry it. let it sit for a day and then lubricate the bearings and gears.
It has always worked for me ..
Dan in Calgary
Living in Calgary Alberta
Threads: 563
I guess short of sliding some insulating film you can't really.
Threads: 242
City: West Bend, Wisconsin
I love my ultra sonic cleaner from Harbor Freight for cleaning tuning capacitors. I fill the tank with 3 cups of water and one cup of Simple Green. Does a great job cleaning...and the tuning cap comes out smelling good too!
http://www.harborfreight.com/25-liter-ul...63256.html
Threads: 563
Except it won't cure a bent vane.
Threads: 242
True....but it does get the pesky rust dots and other debris out from between fins that cause scratching when tuning.
Users browsing this thread: 15 Guest(s)
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
There are currently 3134 online users. [Complete List] » 2 Member(s) | 3132 Guest(s)
