Help identifying this mid-30's Silvertone
A friend sent me these pictures of a radio he has that has been passed down from generation to generation. He was trying to find out what he has. I can tell from the dial it's a Silvertone, but the label on the chassis is badly deteriorated so no model number is visible. Can anyone shed some light on the model number / year? I'm guessing around 1934-35.
Thanks.
Looks to be a model 1938 from '36.
http://mcclellans.com/Silvertone1938Restoration.htm
Thanks!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
