philco model 111 resistor help
can,t find resistors with right ohms ones i need are 13,000 250,000 17,000 25,000 can i run two in series 10,000 3,000 ect thanks denver. Icon_confused:
Use the closest modern equivalents with the right wattage as replacements. Those original resistors only had a 20% tolerance anyway so if you ghet within 10-20% you will be ok.
Here is a table of available modern values:
http://www.radio-electronics.com/info/da...values.php
thanks a bushel and a peck mr. schwark
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2268 online users. [Complete List]
» 2 Member(s) | 2266 Guest(s)
