Zenith 5D610 dial cord diagram
Hello forum -
Anybody come across a dial cord routing diagram for a Zenith 5D610? I've looked in the usual places, Googled quite a bit, and still have not found anything. I am most interested in how many turns the cord wraps around the tuning shaft itself. Any clues?
Welcome to the Phorum!
Icon_wave
sorry, don't have that info.
Hmmmm,
 I have a 6-D-510 but for the life of me I cant tell a difference...
I think it is the same and I literally just changed mine.
Does yours have 2 springs soldered onto the wheel?
If so then it is an easy string.
one end of the string goes on one end of the string. run it strait down under the chassis and wrap it 2 times clockwise.
The up through the oval hole to the other side if the wheel. Tie it fairly tight so the spring has opened a bit.
Here is the string guide that resembles it most.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
