Emerson Model 1002
Ok, Here is the next radio Its a Emerson 1002.. Looks a little like one of Kirk's radios... It uses 6 Tubes...
[Image: http://i292.photobucket.com/albums/mm38/...j0wgsh.jpg]
Started Recap.. About 1/2 way done..
[Image: http://i292.photobucket.com/albums/mm38/...q7kqaw.jpg]
No surprises yet.. Will see if cabinet cleans up.. I hope so..
Skip...
Well looks like I did a little cleanup on Cabinet before.... Doesn't look bad..
[Image: http://i292.photobucket.com/albums/mm38/...lr6wjs.jpg]
One question The Emerson on front show it be a different Color? Or just as is..
Skip...
Lookin' good. I like those large dial glass models, cabinet looks nice. How do you polish? After the cleaning do you use any "secrets".
5 or 6 tube?
Thanks.. I used Don Aslett's Wood Cleaner and Polish. Got it at home depot when I picked up the Howards Re-finisher for my wood cabinets..
It was the only thing I had that I thought would probably work.. So I tried it on inside and it looked good..
Its a 6 tube.. The 6th tube looks like a amp for Headphones?
Skip...
Thanks Skip, missed your title indicating the 6 tube.
Looks cool, good luck.
Ok Finished up the recap and out of Tolerance Resistors..
[Image: http://i292.photobucket.com/albums/mm38/...eftpgc.jpg]
Brought up on Variac.. at 115 Volts draws about .20 Amps.. Stared to play just fine Many stations heard also The Canadian Station on 740 AM Load and clear..
Need a touch up on the dial .. Other wise will put together tomarrow..
[Image: http://i292.photobucket.com/albums/mm38/...axofgk.jpg]
Doesn't need any alignment as it plays just fine and many stations received ..
Skip...
Looks super Skip
Icon_smile
hey skip
nice job looks great Icon_clap Icon_clap
since you keep picking them from storage
where are you displaying them ? don`t think you ever said yet
are you keeping them all or selling at Kutztown
sam
Well, Good Question I planed on keeping them.. But right now have no place to display them. They are on a shelf in Garage right now.. I probably have about 15 or so left to do..
Wasn't planning on selling But who knows..
I just like working on them.. Been getting them from the Shed at Joe's that Terry,Kirk and Friends Visited Every time I go over I find something different I had not seen before...
Skip...
I have the same issue,
I LOVE restoring them but not keeping them.
I keep my 1930's Philco's, my Halson's, and my Hallicrafters but besides some really neat off brand mantle sets I don't collect much else. I ended up having 60 radios that I did not know what to do with. I keep buying them when I run out of projects and I don't think I have any family or friends left to give one to who would care. Icon_lol
Bring some to Kutztown if you want.
I got room for ya.
Icon_smile
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
