Austrian Hornyphon
Hi,
Just acquired this nice looking Austrian Hornyphon radio. I've never looked at a European radio chassis so don't know if this will be a challenge or not. First of all, can I just plug this into 220 volt and expect no power supply problems? Will the 50 hertz spec be OK? Anything that I can expect to cause me trouble or confusion?
Alan
Hi Alan,  A photo and model number of the Hornyfon would help us assist you.  Thanks,  Joe
Joe
Hornyfon.....I thought it is a phone sex service's name Icon_lol
I always wanted one of those just so I could tell people that I had it.
Doesn't look all that horny to me......Icon_smile
That name definitely made me do a double take! Some things just don't translate well...
mike   No   Icon_problem
sam
Here's a photo, a Prinzess W362A
Looks like other models have a voltage selector, but not this one.
OK.
Now we add the "princess" to the name.
No really....this is too much Icon_lol
Here's my Hornyphon before I restored it.  This one is the W455X "Potentat".
Sean
WØKPX
I bite my tongue......their naming system was clearly devised by someone who read too much of the Playboy.
Icon_lol
Maybe these radios are like the band Toto. You chuckle at the name, then they blow you away with their performance!
German / European radios are very good, but american are still better on average, though some European ones are really stylish.
So no blowing away....just pleasant sound.
It isn't usually a problem to power a 50 cycle device on 60 cycle, unless it has an AC motor in it in which case the motor may spin faster. Transformers usually don't care if they are operated at a higher line frequency, within reason of course, but they don't like the opposite. Most European radios have taps on the transformer primary that allow operation on several different line voltages, sometimes it's a plug on the transformer, other times there is a wire that you have to undo from a screw terminal and move to another terminal. You may have to remove the back to get at it if it has a voltage selector, if not come back to us for a plan "B". This Hornyphon looks like a later model from the 1960s if the eye tube is any indication, it looks like an EM84.
Thanks, there isn't a visible panel of plugs like some models so I'll get in there and take a closer look at the transformer.
Alan
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4834 online users. [Complete List]
» 2 Member(s) | 4832 Guest(s)
