Threads: 103
City: Calgary, AB, CA
Threads: 29
City: Wellborn Florida
Bulb number 47, please do not run the radio without a pilot light very hard on the rect tube. Nice Job on the cabinet. David
Threads: 563
Dan, great job!
The wattage.....these are typically 1W or so.
I get the number from the fact that 6.3V time 0.15A is about 1W.
This size bulb won't get it too hot under there.
Threads: 103
I believe that the bulb for this radio is 110 volts, as it is the same size as a Christmas light bulb. I will do a check and get back to you guys..
Dan in Calgary
Living in Calgary Alberta
Threads: 563
It cannot be 110V.
It is plugged between the 35Z5 filament's pins 2 and 3 which are one end and the pilot tap. Considering the filament itself is 35V, the tap voltage when unloaded is 15V, when loaded - 5V so the bulb is likely to be 5-6V.
This is I think the same for 46-420 or 46-460 versions.
Threads: 415
City: Boston
#47 would be 6V, I have a hippo, fairly certain that is what it has. Mine not so pretty, lost the Philco label somewhere along the line.
Threads: 11
City: Bellmawr, NJ
OH NO,,,DON'T POKE THE BEE HIVE,,,,,THESE GENTLEMEN KNOW THIER STUFF,,,,THANK YOU,,
Threads: 103
Kenneth. I believe them, that is why I asked the question about the bulb.
Thanks Dan in Calgary
Threads: 54
Dan;
It seems to depend on the code number, and production run, as to what pilot lamp the Hippo models use, some use a G.E #47 or equivalent, others use a 120 V night light type bulb. I think that the sets that used a 35Z3 (Loctal) used the 120 Volt night light bulb, basically a Christmas light bulb, since the 35Z3s don't have a pilot light tap on the filament. In any event they sell LED substitutes for night light bulbs in Walmart and some other stores, that would eliminate the potential melting plastic issue these sometimes get.
Threads: 103
Thank you Arran
Mine has a large screw socket and I can put in a LED night light , but it is too large to fit in the space where a little smaller bulb would go. The LED night light is just a tad too wide.
I will post some photos of the socket and set up I have .
Dan in Calgary
Threads: 103
Threads: 29
Dan your rect tube looks to be something other than a 35Y4. The standard night light is 7 watts but you can find clear 4 watt bulbs or just leave it out. Could you please give a list of all tubes in your set. Thanks David
Threads: 103
The tubes in this radio are ,,,,,,,,35Z5, 14AF7, 7B7, 7B7, 7C6 and 50L6
Dan in Calgary.
Threads: 415
City: Boston
I have a GE that has a bulb like that, put in a Red One for Christmas!
GE202.
Threads: 563
It is strange that they used 35Z5 and then did not utilized the filament pilot lamp tap.....
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
There are currently 2639 online users. [Complete List] » 2 Member(s) | 2637 Guest(s)
