Aerial Label
Does anyone know what the original color combo was on this 37-610 Aerial label? I'm trying to create a new label using this old one as a guide.
I'm assuming it was black and white and like every thing else has turned brown with age, but I wanted to make sure. Thanks in advance.
Kelly
"He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
That label is printed in a dark navy blue. I previously created a repro of it here:
http://philcoradio.com/phorum/showthread.php?tid=13296
In many photos the label has darkened and almost looks black. The original color shows up a bit better in this photo (compare to the black tube bases).
https://drive.google.com/open?id=0B64cfW...083UFZiZ2s
Thanks Nathan.
Good job by the way.
Kelly
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7453 online users. [Complete List]
» 3 Member(s) | 7450 Guest(s)
