Looking for voltage tables for a Philco model 41-285 code 121
I has been a while, since my posts, up on the Phorum !
 I will be working on a Philco model 41-285 code 121 soon , I've checked Riders and Philco Bulletin # 352 for the voltage tables , with NO luck , I was able to find the complete schematic and the parts page references, in #352 . Is their one page of just voltage tables in the Philco product in the reference materials ?
   Thanks for your help, Lee Petrie Joliet, IL.
Lee, Hope this helpful. David
Thanks very much, David ,  I knew of Beitman / Supreme manuals ( maybe a few around the house ) , that was exactly what I was  looking for, with my post !  Are they listed , like Riders on Nostalgiaair , somewhere on the internet ?
  Lee Petrie, Joliet, IL.
David ,  I found the "on line version of the Beitman / Supreme manuals " ,  I always thought , those small books were the inexpensive version on the Riders manuals , and weren't nearly as complete , I was wrong !
   Thanks for all of your help, Lee Petrie, Joliet, IL.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7325 online users. [Complete List]
» 3 Member(s) | 7322 Guest(s)
