35A5 tube substitution
Thanks for the info. I'm learning a lot about tubes . Now if I can just remember it .
walt
Could be since your filament voltage is low, (due to the 50A5) is the reason your radio has 'other problems'.
Tim
Yeah that could be. But I noticed that somebody before me had worked on the speaker extensively and probably couldn't fix it .
Strangely ,I just discovered that a Philco 41-225 that I have has exactly the same chassis as the 41-220 except for the push button feature and it also has a 50A5 tube in it and it works OK. I do have a 35A5 coming and I will use it .
But I am sure the speaker has problems and I'm looking to get it rebuilt or purchase a good used one IF I can find one. There should be one out there somewhere since they probably made thousands of these radios. Thanks for your input.
walt
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3964 online users. [Complete List]
» 3 Member(s) | 3961 Guest(s)
