Threads: 24
City: Edmonton AB CA
Has anyone bought chassis labels from this fellow, see link below. His ad says he will make what ever label set you want so I asked him for a set for my model 17B and he emailed back and said he's to busy and can't do it. Seems to be a little false advertising to me.
http://www.ebay.com/itm/Philco-Tube-Radi...xycmBS3icT
Gregb
Threads: 310
City: Kings Park NY
Avoid him..
Stuff is crap and he is not a nice person or a good salesman...
Me
AC: 4 DC: 1
Threads: 24
Your are absolutely correct in that statement!
Gregb
Threads: 214
City: Seattle
State, Province, Country: WA
Chuck Paci (cpaci1 at Verizon dot net) sells photo reproductions of original labels.
I'd also be happy to help make some (for the fun of it) - but these would be reproductions rather than scans.
Just to confirm, this is the radio you have:
Gallery link:
http://www.philcoradio.com/gallery/1933b.htm#f
Assuming that's right, here are examples of labels from the 17B:
Chassis label
The chassis label looks pretty much like this 16B label:
http://philcoradio.com/phorum/showthread.php?tid=13832
Patent label
The patent label is essentially the same as this one, just printed larger:
http://philcoradio.com/phorum/showthread...#pid118218
Tube layout label
Threads: 24
Thanks Nathan, that is the radio! If you would make me a set that would be greatly appreciated. PM me the details.
Gregb
Threads: 22
City: Waxahachie, TX
(12-23-2016, 07:52 PM)OldRestorer Wrote: Avoid him..
Me
Ditto!
Crist
Threads: 214
City: Seattle
Repro labels for the 17B added to the Downloads section:
http://philcoradio.com/phorum/showthread.php?tid=16003
Threads: 26
City: Wilmington
State, Province, Country: NC
(12-25-2016, 08:25 AM)Crist Rigotti Wrote: (12-23-2016, 07:52 PM)OldRestorer Wrote: Avoid him..
Me
Ditto!
DITTO AGAIN
Bob T
Got stung with Crap. He just does not care
Threads: 566
Chuck seems to make good labels, plus some other things like tube shields. Can't say anything on the seller in question, but I usually go to the people I know and trust first.
Threads: 337
City: lawrenceville nj
So why not try ones Nathan uploaded
Sam
Threads: 22
Well, I got stung by this guy again. Avoid Vintage Radio Labels.
I need a foil RCA "Golden Throat" Label for my 1946 RCA 621TS TV that I'm restoring. He had one and I bit. Here is what he advertised and what I received. A paper one and notice the ladies face color!
[Image: http://i1060.photobucket.com/albums/t458...ndwnzz.jpg]
I may contact Nathan. He is skilled and does a great job on these things.
Crist
(This post was last modified: 04-01-2017, 04:39 PM by Crist Rigotti.)
Threads: 214
City: Seattle
Thanks very much Crist. Funny story - I started making labels *because* I ordered one from the same seller and was unhappy with the quality.
Let me know if I can help. From the examples of that label I've seen online it's a bit of a tricky one to reproduce because it requires a gold background (which is normally OK - that just means printing on gold paper with a color laser printer) but also white lettering. Obviously most printers don't print white (or gold), which makes having both in the same label a bit of a problem. Probably the best you could do with a regular printer would be to print the golden-yellow rather than have it be metallic.
Threads: 566
Crist
Do you know the joke about stepping twice on the same rake?
Threads: 22
(04-01-2017, 07:32 PM)morzh Wrote: Crist
Do you know the joke about stepping twice on the same rake? ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif)
Apparently not!
Crist
Threads: 22
(04-01-2017, 07:15 PM)Nathan Slingerland Wrote: Thanks very much Crist. Funny story - I started making labels *because* I ordered one from the same seller and was unhappy with the quality. ![Icon_rolleyes Icon_rolleyes](https://philcoradio.com/phorum/images/smilies/icon_rolleyes.gif)
Nathan,
Got your email. Looking into this label a little deeper. I need a good size dimension to begin with. We'll keep in touch over the next few days.
Crist
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
