Correct toner laquer for Philco 90a
Hi Guys,
What color toner should be used for the front columns and base moulding on a 90a cathedral?
Thanks in advance for your authoritative suggestions!
Hi - I don't know the answer myself, but if you haven't already seen this, here is a very extensive Philco 90 refinishing walk-through:
http://antiqueradios.com/forums/viewtopi...7&t=220363
And another recent restoration:
http://philcoradio.com/phorum/showthread.php?tid=14782
Eico 232 VTVM Schematic
There are currently 9949 online users. [Complete List]
» 1 Member(s) | 9948 Guest(s)
