Philco 46-1209 code 122
Hi all,
i have a Philco 46-1209 122 that seems to be missing the needle or stylus.....what are the chances of finding a replacement??
Good morning and welcome,
Since this topic is not about auto radios I moved it to a more appropriate section (Philco Electronic Restoration).
But to answer your question...I can think of two sources where you might find a stylus for your 46-1209 phonograph.
http://www.west-techservices.com/
http://www.garage-a-records.com/
Good luck!
Thanks, as allways Ron...
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
