philco 46-1209 stylus/cartridge info
hi guys!
i'm trying to finish up on this one,need stylus and cartridge numbers-the needle is nothing but a stump!
it saw plenty of use i'd say.
thanks,phil
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2401 online users. [Complete List]
» 1 Member(s) | 2400 Guest(s)
