Have Philco Transitone T-3
Looking for schematic and service information for a Philco Transitone T-3. Also may be known as a Studibaker-Philco ST-3. 6 Tubes and 1 large 4-pin 6V vibrator. Most usual sites have been dead-end. Beitman and Raider no go as well or I am  not looking it up correctly.
NOTE: Chassis Model T3 Code 121
Dave KB7GP
Welcome to the Phorum Dave!
It looks like the picture attachments are missing from your message. You can try adding them again by clicking the 'Edit' button followed by 'Full Edit'.
As for the service information, your best bet would be Chuck Schwark at philcorepairbench.com:
http://www.philcorepairbench.com/schematics.htm
He provides excellent quality copies of Philco service information.
(04-02-2017, 11:39 PM)Nathan Slingerland Wrote:  Welcome to the Phorum Dave!
Hey thank you... Don't understand. when I prevued the post everything was fine.
Does this sound like a number you may have in your files? I will try to see where the attachments went.
Ok it looks like the attachments are there now ??
Dave
Yup - not sure what happened, but the pictures are there now. Icon_thumbup
I have several Riders Volumes. I can check tonight after work to see if I have it. Nostalgia Air may not have posted the complete info for some reason, but I noticed while looking through my Riders that they are covered. Service info is there, but the schematic is not on Nostalgia Air.
http://www.nostalgiaair.org/Resources/222/M0014222.htm
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Nathan's suggestion is probably the way to go. I just checked and my Riders was the same as what Nostalgia Air had, unfortunately.
Blessings,
Jeff W.
Jonesboro, Arkansas
