capacitor block model 111
please could you tell me what caps goes in this box ordered some caps looked at audins post mine are marked 1.0uf 0.47uf 0.22uf 0.15uf 0.047uf 0.015uf 0.01uf 630volts thanks Denver Icon_rolleyes Icon_confused:
Denver,
Have you looked at Ron's schematic?
http://philcoradio.com/tech/images/111.jpg
Carl
Northern Panhandle, WV
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
